diagnostic control => betekend dat daar de sensor inzit die een klap registreerd? want ik heb nog geen mpi"s gesloopt dus ben nog geen sensors tegen gekomen. Ik heb wel al meerdere malen een MPi stuur verweiderd enz dus das geen probleem.
RE: Airbag
Ingediend door Theo van den Bogaard op di, 12-07-2005 10:19
het kastje onder de achterbank heet "diagnostic control unit" (het bepaalt of de klapzak afgaat of niet)
er staan nogal wat veiligheidsvoorschriften in de manual wat betreft het behandelen en opslaan van airbags
"DRIVERS AIRBAG MODULE
Service repair no - 76.73.71
CAUTION: See safety precautions before
commencement of repair.
Remove
1. Remove key from starter switch, disconnect
both battery leads, earth lead first, and wait 10
minutes for the SRS back-up power circuit to
discharge before commencing work.
2. Remove 2 Torx bolts securing the air bag
module to steering wheel.
3. Release air bag module from steering wheel.
CAUTION: Do not allow the air bag module
to hang by the air bag harness.
4. Disconnect harness connector from air bag
module.
5. Remove air bag module.
CAUTION: Store the air bag module in
accordance with the storage procedures
outlined in the precautions part of this
section.
NOTE: If the air bag module is to be
replaced, the bar code must be recorded.
Refit
1. Position air bag module and make connection
with harness upwards as shown in illustration.
2. Fit air bag to steering wheel and hand start the
2 Torx screws. Tighten screws to 7 Nm.
3. Connect battery leads, earth lead last.
4. Carry out system check by turning the ignition
on and checking that the SRS warning light
illuminates then extinguishes after 3 seconds."
etc. etc.
