When the engine is warm and then turned off I am experiencing a problem starting the engine again. It WILL start again immediately after it is turned off, but if left turned off for a few minutes it will NOT start again until the engine has cooled down.
I am thinking that this might be a fuel problem, possibly something to do with one of the many sensors.
Has anyone else experienced this?
Bedankt
Ian
PS soory voor het engels
Possibly an petrol problem.
It can also mean that there is a hole in a hose or maybe the lambda wire is broken or making no contact.
Maybe you can drive to a Rover dealer to read you're computer out to see some faults like information missing what the comp needs to work properly.
What you also can do is lose the - wire from you're battery for a few minutes to reset you're comp.
Help needed from all you miniacs!!!
I have a 1997 Mini Cooper 1.3mpi.
Bedankt
Ian
