VIN code
Hallo mini liefhebbers,
Kan iemand mij wat meer vertellen over de VIN code van mijn mini?
Het nummer is: SAXXL2S1S21501378
Alvast bedankt!
Dit hheb ik in een documentje op mijn HD:
Mini Chassis/VIN Numbers and Commission Numbers
Part 2: 1980 – 2000
The information used to compile the following was taken from factory service parts lists, factory microfiche, and factory CDs. Under close scrutiny, there appears to be some conflicts and mistakes in the factory number schemes, but, for the most part, the listings are accurate enough for car identification.
Please note that the Chassis (VIN) number and the Commission number are only one indication of the actual model and date of the car. The Chassis number plate is easily duplicated, especially on early cars, and it is not unusual for later cars not meeting US DOT and EPA standards to have earlier Chassis number plates attached to them to get them into the US illegally. Also, Chassis number plates have been known to be “faked” to turn a less valuable car into a more valuable one; e.g., a standard Saloon into a Cooper or Cooper S.
[size=150:8mv2qb2z]Oct 1980 to Nov 1985 – English Built[/size:8mv2qb2z]
Note that the VIN plate for these cars is likely marked, “Austin Rover Group LTD”
It is possible that the dating in the factory microfiche is incorrect and the change date is October 1984, not 1985. Major changes were made by October 1984 (for instance, 8.4” brakes and 12” wheels became standard).
The general format for the VIN for these cars is:
SAX-X-K2S1N-XXX-A
First Three Positions (“SAX” in the above example):
This is the World Make Identifier. The factory microfiche indicates this was started on these cars in Feb 1981. SAX = MG-Rover
Fourth Position (“X” in the above example):
This is simply dismissed by the factory as “non significant”!
Fifth Position (“K” in the above example):
= Engine type:
C = 1098cc
K = 848cc
L = 998cc
Sixth (and Seventh) Position (“2S” in the above example):
= Body type:
2S = 2-door saloon/sedan. Caution: bureaucratic bungles often interpret this as 25 (twenty-five)
2W = Estate (“2 Door Dual Purpose”)
G = P.O. Mail Van
U = Pick-up. Caution: U and V can be mistaken one for the other.
V = Panel van. Caution: U and V can be mistaken one for the other.
Eighth Position (“1” in the above example):
= Series of model:
1 = Round nose, traditional Mini body style.
2 = Clubman, square nose style.
Ninth Position (“N” in the above example):
= Specification:
N = HL, Special, HLE, or Mayfair
R = Mini 25
S = Mayfair (LHD – France only)
Number positions (“###” in the above example):
= The sequential build number:
Build numbers are not listed. It is suspected that they carry on with the numbers from the previous series of cars; i.e., numbers were not started from 101, again.
Last position (“A” in the above example):
= Assembly plant. Officially, “Internal Use Only”
If used at all, this would be “A” for English built cars.
A = Longbridge
[size=150:8mv2qb2z]Nov 1985 to Circa 1990?? – English Built[/size:8mv2qb2z]
It is possible that the start date is really November 1984, not 1985 as stated in the factory microfiche.
SAX-X-L2S1N20-XXX-A
First Three Positions (“SAX” in the above example)"
SAX = MG-Rover
Fifth Position (“L” in the above example):
= Engine type:
L = 998cc
= Body type:
= Series of body:
= Class:
N = HLE, Mayfair (RHD)
O = E, City E
S = Mayfair (LHD)
Tenth Position (“2” in the above example):
= Model year:
2 = 1984 on (This conflicts with the microfiche indicating this position was used starting in November 1985.)
Eleventh Position (“0” in the above example):
= Steering:
0 = RHD
1 = LHD
A = Longbridge
[size=150:8mv2qb2z]1990 XN-----010001 On (1300cc cars only) – English Built[/size:8mv2qb2z]
SAX-XN-N-A-Y-B-B-D-######
= World Make Identifier:
SAX = MG-Rover
Fourth and Fifth Positions (“XN” in the above example):
XN = Mini 1300
Sixth Position (“N” in the above example):
= Class:
N = Sport, Cooper, Cabriolet
V = Kensington
W = HLS, Mayfair
Y = City, Sprite
Seventh Position (“A” in the above example):
= Body type:
A = 2-door saloon/sedan.
B = Cabriolet
Eighth Position (“Y” in the above example):
= Engine:
D = 1300 Carb
M = 1300 Carb
X = 1300 SPi (standard compression ratio, 9.4:1)
Y = 1300 SPi (high compression ratio, 10.1:1)
Z = 1300 MPi (high compression ratio, 10.1:1)
Ninth Position (“B” in the above example):
= RHD/LHD, Transmission type, Final Drive:
B = RHD, Manual, 3.105
C = RHD, Manual, 3.21
E = RHD, Manual, 2.76
K = RHD, Automatic
M = LHD, Manual, 3.105
N = LHD, Manual, 3.21
R = LHD, Manual, 2.76
Y = LHD, Automatic
Tenth Position (“B” in the above example):
= Model Change:
A = 1300 Special Edition
B = 1300
Eleventh Position (“D” in the above example):
= Assembly Plant:
D = Longbridge
Number positions (“######” in the above example):
= The sequential build number, starting with 010001
Dus ff jaar opzoeken en dan verder kijken :)
Het gaat dus om een linksgestuurde 'normale' Mini 998 Mayfair als het in de gauwigheid goed heb opgezocht.
edit: Ow, ik heb blijkbaar hetzelfde als de link van Theo |:( maar goed, mocht die site ooit verwdijwen staat de info safe op het forum ;)
