Ingediend door SEVEN - TY - ONE op zo, 17-06-2012 23:24
If you visit this week's Goodwood Festival of Speed in the UK, make sure you stop by Cummins' stand to check out this one-of-a-kind Austin Mini with a unique engine-swap. In case you didn't notice, there's a colossal engine sitting just behind the passenger compartment on the classic Mini's stretched platform.
Cummins, an independent maker of diesel engines, fitted its biggest powerplant on one of the smallest cars around. The QSK78 diesel engine, which is used to power mining industry dump trucks capable of carrying 360 tonnes, is a 78-liter, 18-cylinder monster with 12 turbochargers producing 3,500HP (take that Veyron) at 1,900 rpm and 10,157 lb-ft / 13,771Nm of peak torque at 1,500 rpm.
Weighing in at over 11 tonnes (24,912 lbs), the V18 unit measures an astonishing 3,327mm (131-in.) in length, 1,633mm (65.5-in.) in width and 2,429mm (95.6-in) in height.
"We never like to let a challenge go by unanswered so we got to thinking maybe we could fit the QSK78 into an original Austin Mini," said Steve Nendick, Cummins' Communications Director. " It proved to be a bit tricky to fit under the bonnet but our engineers came up with a more creative solution. We're certain that the Goodwood crowd will have difficulty believing what they are seeing", he added.
No word from Cummins on whether or not the V18 diesel actually motivates the Mini, but we wouldn't bet on it.
RE: Mini met het grootste motorblok ooit?
http://automotivemansion.blogspot.nl/20 ... iesel.html
