HEt is niet alleen het frame, maar een set: (indien pro-motive betreft)
* Mini front sub frame powder coated silver complete with mountings for engine and driveline
* Bespoke tubular exhaust manifold with insulation wrap fitted (mates to 2" mini performance exhaust system)
* Custom made oil immersed differential assembly with remote aluminium breather, fitted with 4 pin diff as std, takes standard length mini drive shafts
* Complete chain drive with H/D Z ring 530 chain, self adjusting tensioner system and interchangeable ratios
* Hydraulic clutch release mechanism.
* Remote oil filter assembly and s/s pipe work, takes standard R1 filter
* Gear lever linkage and cable (bolts into original floor position)
* New custom radiator, silicone hoses and s/s clips
* Fully bearinged high output electric fan with fitting kit
* Aluminium chain guard
* Pipe work for heater connections
* All zinc plated fixings and brackets
* Comprehensive fitting instructions
Prijs 3250 pond (idd 4000E)
Linkje:
http://www.pro-motive.co.uk/R1KitInfo.html
Jaapio[/list]
RE: R1 blok in het vooronder...
Ingediend door BadBert op di, 26-08-2008 08:21
Pfoe, dat dat subframe zo duur is had ik niet gedacht!
